14 years agoIgor Mac and DP83848 dont read data
Hello all,
I have board with Cyclone III (EP3C25Q240) with DP83848C and design in sopc builderu(igor_mac - clk_0=60MHz, irq=7,...) + quartusu. After this i build my uClinux - Ethernet 10/100Mbit - - Generic Media Interface ... support - Opencores (Igor) Emac support and - Networ device support - driver for National semic. PHY after starting it looks ok, ------------------------------------------------------ /> dmesg Linux version 2.6.30-rc6 ([email protected]) (gcc version 3.4.6)# 33 89 PREEMPT Fri Apr 6 13:15:41 CEST 2012 uClinux/Nios II On node 0 totalpages: 4096 free_area_init_node: node 0, pgdat 011d4fb8, node_mem_map 01338000 DMA zone: 32 pages used for memmap DMA zone: 0 pages reserved DMA zone: 4064 pages, LIFO batch:0 Built 1 zonelists in Zone order, mobility grouping off. Total pages: 4064 Kernel command line: NR_IRQS:32 PID hash table entries: 64 (order: 6, 256 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 12948k/3149k RAM, 0k/0k ROM (1664k kernel code, 1484k data) Calibrating delay loop... 29.49 BogoMIPS (lpj=147456) Mount-cache hash table entries: 512 net_namespace: 264 bytes NET: Registered protocol family 16 init_BSP(): registering device resources bio: create slab <bio-0> at 0 NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 512 (order: 0, 4096 bytes) TCP bind hash table entries: 512 (order: -1, 2048 bytes) TCP: Hash tables configured (established 512 bind 512) TCP reno registered NET: Registered protocol family 1 io scheduler noop registered io scheduler deadline registered (default) ttyJ0 at MMIO 0x20070a0 (irq = 1) is a Altera JTAG UART console [ttyJ0] enabled ttyS0 at MMIO 0x2007040 (irq = 5) is a Altera UART ttyS1 at MMIO 0x2007060 (irq = 6) is a Altera UART eth0: Open Ethernet Core Version 1.0 oeth_probe: 60000 Khz Nios: 16 RX, 16 TX buffs NO Custom HW ALIGN. CONFIG_NIOS2_HW_MULX NOT defined. CONFIG_NIOS2_HW_MUL_OFF NOT defined. BMCR = 7fdfh. TCP cubic registered NET: Registered protocol family 17 RPC: Registered udp transport module. RPC: Registered tcp transport module. Freeing unused kernel memory: 1260k freed (0x11d8000 - 0x1312000) oeth_phymac_synch:eth0 MR1: 0x00007FDF Jabber Remote Fault Link OK: MODER: 0x0000A040 FullD 100BASE-TX   oeth_phymac_synch:eth0 MR1: 0x00007FDF Jabber Remote Fault Link OK: MODER: 0x0000A440 FullD 100BASE-TX but when i use ping to pc, the data i can see in wireshark, but the data dont read back: /> ping 192.168.2.200 -c 5 PING 192.168.2.200 (192.168.2.200): 56 data bytes --- 192.168.2.200 ping statistics --- 5 packets transmitted, 0 packets received, 100% packet loss /> and statistics after stopping my net sending program looks: /> ifconfig eth0 Link encap:Ethernet HWaddr 00:07:ED:0A:03:29 inet addr:192.168.2.2 Bcast:192.168.2.255 Mask:255.255.255.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:131484 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:64822812 (61.8 MiB) Base address:0x4000 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) Why the ip or nios dont read the data from ethernet line ? Some idea ? Thank you very much Jan Naceradsky, Czech RepublicNo RepliesBe the first to reply
