21 years agoIDE New Project needs writable memory
Hello: I'm attempting to create a second project in the Eclipse IDE The design uses a cyclone and I've got a simple NIOS-II with real general FPGA logic function. For memory I ha...
21 years agoPerhaps I didn't make this clear enough.
I've created a NIOS II project and plan to use a simple FLASH and STATIC RAM to hold the program and stack. I connect the FLASH and RAM using the 'interface to user logic' module in SOPC builder. When I try to create a new project in the ecipse IDE I get an error that there is no writable memory. So How do I convince the IDE that the RAM at the end of the interface to user logic is OK to use?? Thanks George
