ARačk
7 years agoI need help with the testbench which read from the file.
LIBRARY ieee; USE ieee.std_logic_1164.ALL; USE ieee.numeric_std.ALL; ENTITY signed_mult18 is PORT( a : IN SIGNED (17 DOWNTO 0); b : IN SIGNED (17 DOWNTO 0); result : OUT SIGNE...
ARačk
7 years agoTest the 18x18 multiplier created by the translators for sign numbers (numbers
expressed in the supplementary code) and verify the created multiplier by:
a) Numbers A = -RRRR and B = DDMM, where YYYY, MM, DD are the year, month and day of your birth.
b) using another 10 suitably selected sufficiently large input values A, B,
each of which has at least one unit and one zero in the four most significant bits
half of the numbers tested are negative. Entry values must be entered as input
the text file and the accuracy of the results must be automatically verified using testbench
file.
