MChin10
7 years agoI am trying to build my code in NIOS getting error
./lights_example_bsp/\libhal_bsp.a(alt_main.o): In function `alt_main':
C:\intelFPGA\16.1\qsys_tutorial\software\lights_example_bsp/HAL/src/alt_main.c:154: undefined reference to `main'
collect2.exe: error: ld returned 1 exit status
make: *** [lights_example.elf] Error 1
please help me on this
- AnandRaj_S_Intel
- Can you clean build your bsp library and then generate bsp and build project and check.
- Please check your console if any message related to memory or message like on_chip_memory is not within region? if so, increase your onchip memory size in qsys design.(After generating qsys system check time stamp of sopcinfo file)
Anand
- MChin10
Hi Now I am getting following error while running NIOS Downloading ELF Process failed pausing target processor :not responding resetting and trying again: FAILED loading target processor failed regards, Mounica- AnandRaj_S_Intel
Hi Mounica,
Connect cpu.data_master to all program memories
- We may see above error.If your board is in reset state you or cpu.data_master is not connected to all program memories.
- Check the switch state of reset.
- check the cup.data_master connection.
- Check the reset and clock pin assignments.
Anand
