NanjundaM's avatar
NanjundaM
8 years ago
HPS not responding to the commands with EDS command Shell for flash
We are facing the below error for the write through the HPS JTAG to QSPI flash connected.
Below are the prints:
$ quartus_hps -c 1 -o P qspiimage.img
Info: *******************************************************************
Info: Running Quartus Prime Programmer
Info: Version 16.0.0 Build 211 04/27/2016 SJ Standard Edition
Info: Copyright (C) 1991-2016 Altera Corporation. All rights reserved.
Info: Your use of Altera Corporation's design tools, logic functions
Info: and other software and tools, and its AMPP partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Altera Program License
Info: Subscription Agreement, the Altera Quartus Prime License Agreement,
Info: the Altera MegaCore Function License Agreement, or other
Info: applicable license agreement, including, without limitation,
Info: that your use is for the sole purpose of programming logic
Info: devices manufactured by Altera and sold by Altera or its
Info: authorized distributors. Please refer to the applicable
Info: agreement for further details.
Info: Processing started: Fri Sep 21 14:52:06 2018
Info: Command: quartus_hps -c 1 -o P qspiimage.img
Current hardware is: USB-BlasterII [USB-1]
Found HPS at device 2
Double check JTAG chain
HPS Device IDCODE: 0x4BA00477
AHB Port is located at port 0
APB Port is located at port 1
Double check device identification ...
Warning: Overwrite detected IDCODE
Setup non-secure transaction ...
Boot Info: 1.8V QSPI Flash
Clock Select: 0
Start HPS Quad SPI flash programming ...
Initialize QSPI peripheral and flash controller ...
Assuming QSPI controller system clock is 50Mhz
QSPI controller baudrate setting: 32 (15)
Read Silicon ID of Quad SPI flash ...
Error: Fail to poll the QSPI Command execution status
Error: Fail to read Silicon ID
Error: Quartus Prime Programmer was unsuccessful. 0 errors, 0 warnings
Error: Peak virtual memory: 4270 megabytes
Error: Processing ended: Fri Sep 21 14:52:07 2018
Error: Elapsed time: 00:00:01
Error: Total CPU time (on all processors): 00:00:00
We were able to program the same 2days back and all of a sudden it started giving this error.!! (Though there was some issue with the JFFS2 FS mounting)
From the above errors, could you please let us know what could be the issue?
Meanwhile we checked the clock,data& chip select pins during the command execution and we were surprised to see that these were not at all responding. Though they are toggling nicely when I give a hard reset from the reset switch connected to the HPS POR pin.
At present we have a single board and its a custom board. So we do not have the working copy/working captures of the QSPI clock,chip select and data to compare with. (we are running the 16.0 EDS command shell for QSPI program through JTAG & We are doing the FPGA configuration separately with EPCQL, File is generated from the same FPGA project, We have also tried just erase command {quartus_hps -c 1 -o E}, we are using the same tested flash from micron, MT25QU01GBBB8E12-0SIT, The boot select pins are fine and working proper{as we see some signals toggling for QSPI interface with reset}, Hardware point of view, we see proper voltages on the voltage rails)
Can anyone please help.
Thanks & Regards,
Nanjunda M
