9 years agoHPS load hangs after RBF is loaded
Hello, I had a working QSYS design with HPS & FPGA communication through the H2F bus. The Linux on the HPS loaded well and everything functioned as intended. I then decided to enable the...
9 years agoThe problem could be in the bridge,
one option is that it is not initiated during boot, another option is that it is used wrong in the software or hardware. This will cause the HPS to freeze once the bridge is used.
