9 years agoHPS GPIO's ouputs stuck in high impedence?
I have an issue regarding a custom board the GPIOs where all the HPS IO’s are set to high impedance no matter to how they are set. I have tested the following: GPIO system on linux enablin...
9 years agoHi kyle ,
How do I use the Device generator to create the .dtb file??...since all the device tree is in here I need this... steps to create the .img ,dtb and .rbf 1. while I created the .SOF we got the .rbf 2. .img I ran the make and make uboot ,along with bsp editor and got the img 3. .DTB one can use SOPC2DTS command from the embedded shell..but there are 2 .xml required to run clock tree and board xml...I am confused by the names..is it underhps_isw_handoff or the SOC_system folder when we create the .Qsys... 4. If I get all three and do a cat all get the final image and flash onto SD card we should see the GPIO pins glowing.. reached the final step..kindly help. regards Ravi ..kindly let us know. regards Ravi
