9 years agoHPS GPIO's ouputs stuck in high impedence?
I have an issue regarding a custom board the GPIOs where all the HPS IO’s are set to high impedance no matter to how they are set. I have tested the following: GPIO system on linux enablin...
9 years agoHi kyle,
once I complete the preloader using bsp-editor and execute make and make Uboot...the same image I copied onto the card.but Initially I was using a default deo nano image with deo nano .rbf...should I replace the .rbf???....then I wil flash the .SOF and then if I try this image then still my GPIO is in high condition only same as what you have faced.Kindly Let me know how to get over this ...do we need to compile with weak pull up ??? Pl help us kyle. regards Ravi --- Quote Start --- I have an issue regarding a custom board the GPIOs where all the HPS IO’s are set to high impedance no matter to how they are set. I have tested the following:- GPIO system on linux enabling each of the GPIOs as an output through the controller... and writing values to them... (findings it changes to output state but the value doesn’t alter and reads back high - unchanged)
- GPIO controller address read/write (findings values don’t change)
- Pre-Linux Hardware GPIO Loaning Pins driving a value change on preloader startup to enable a LED (findings no value on GPIO changes value)
