9 years agoHPS GPIO's ouputs stuck in high impedence?
I have an issue regarding a custom board the GPIOs where all the HPS IO’s are set to high impedance no matter to how they are set. I have tested the following: GPIO system on linux enablin...
9 years agoHi kyle,
As you suggested the assignment editor is showing GPIO_1[29] to GPIO_1[34] with I/O standard and 3.3 V LVTTL. Still when I access from linux space the GPIO_1[29] corressponds to GPIO198 does not glow. I have chosen Unused pins as Input trigerred...the question is if there is wrong in .SOF how HPS_LED(GPIO_1[53]) is glowing from the linux space... If I give this command echo "leds-gpio" > /sys/bus/platform/drivers/leds-gpio/unbind -sh: echo: write error: No such device why is this error shown...should I map my pin as HPS_GPIO or GPIO_1[29] is more than enough..any specific reason to add HPS_GPIO?? thanks Ravi
