9 years agoHPS GPIO's ouputs stuck in high impedence?
I have an issue regarding a custom board the GPIOs where all the HPS IO’s are set to high impedance no matter to how they are set. I have tested the following: GPIO system on linux enablin...
9 years ago" Hi kyle,
when you go to Assignment Editor there are 2 rows you see for each pins GPIO_1[0] Location( This is changed to HPS_IO) and select Enable(Yes) GPIO_1[1] I/O standard 3.3 V LVTTL Once I did this and compiled and flashed the .SOF then Pin 2 of GPIO_1 cannot be accessed. I have a C file which changes the Set bits and Clr bits..But I am not able to take control of the GPIO_1 pin.Is there any jumper which we need to change.also are my configurations correct. Once I get one pin I can map for others. Kindly let me know." regards Ravi
