ABary
8 years agoHPS DDR3 assigments
I have a prototype board that uses a DDR3 SDRAM connected to HPS in Cyclone V device. The board has a error, bank pins BA[0] and BA[2] are swapped. Is it the way to re-swap this outputs ?
a_x_h_75
Contributor
8 years agoI'm afraid you're stuck. They can be swapped - a restriction of the Hard Processor System you're using. Unfortunately, the I/O is hard wired as well.
Cheers,
Alex
