13 years agoHow would one put the FPGA HW + Nios II SW image together on the following memories
When it comes to external memories to store configuration data, we have the following options:
1. EPCS. 2. EPCQ. 3. CFI Flash. 4. Quad SPI. 5. NAND Flash. If I have a design containing NIOS, how would I put the HW (that comes from .sof) + SW (that comes from .elf) images into a single image to program any of these flash memories? What steps are needed? Are the steps the same for them?2 Replies
For EPCS, you would use the EPCS Serial Flash Controller Core IP block and use a JIC programming file.
For the parallel and SPI flash, I believe you are looking at multiple images needed. - Altera_Forum
i do create my epcs images using the following commands from the Nios Command Shell:
Now i do have 2 flash files which are combined via:sof2flash --epcs --compress --input=hw.sof --output=hw.flash elf2flash --epcs --after=hw.flash --input=sw.elf --output=sw.flash
And converted to epcs binarycat hw.flash sw.flash > image.flash
Now your image.bin can be wriiten directly to address 0 of your epcs, or to another address if you use the Remote_Config IP. I do not have any experience concerning the other Flash types, but think there's an equal approach.nios2-elf-objcopy -I srec -O binary image.flash image.bin
