17 years agoHow to write in EPCS
Hello, I am a newbie with Nios II. I'm doing a robotic project with a Cyclone and an EPCS4 flash memory. I've added an EPCS controller in my SOPC Builder system. I has to read...
17 years agoI don't know much about reading the EPCS to a file. The values you are seeing are your values but bit-reversed (01h becomes 80h etc.). The .jic file probably has a header block before the data too.
I'll do some investigation when I get a chance but in the meantime someone else might be able to answer your question. Cheers
