16 years agoHow to wire to signal tap?
(* keep = 1 *) wire rx_bar_hit/* synthesis keep */;
assign rx_bar_hit = (rx_desc | rx_desc) ? 1'b1 : 1'b0;
But I can't add this signal to Siganl Tap. If I add this signal manualy (just type t...
16 years ago --- Quote Start --- Yes. I'm not use this wire yet. But I'm expected that wire will be used by Signal Tap. So, there are no way to make wire only for Signal Tap? --- Quote End --- Hi, it looks like that, but you can try to capture the wire signal with a register and preserve the register with "noprune". Kind regards GPK
