16 years agoHow to wire to signal tap?
(* keep = 1 *) wire rx_bar_hit/* synthesis keep */;
assign rx_bar_hit = (rx_desc | rx_desc) ? 1'b1 : 1'b0;
But I can't add this signal to Siganl Tap. If I add this signal manualy (just type t...
16 years ago --- Quote Start --- Hi, which setting did you use in the node finder ? Post-Fitting ?? Which Quartus version do you use ? Kind regards GPK --- Quote End --- Hello. I'm try all settings. No one can find rx_bar_hit. Q9.1 Linux 64bit.
