8 years agoHow to verify Avalon-MM slave?
I have written my first Avalon-MM slave component. It shall interface with a Nios II as the master device.
I am a bit lost on how to verify it to make sure that the Nios II shall correctly communicate with it. I have come across something called BFM, it seems to be a new discipline to use them. I am VHDL-person. What steps should I take to learn and prepare a testbench to verify this Avalon-MM slave component.1 Reply
Check the link,this may help you to setup test environment for Avalon-MM slave using BFM. see page 53. https://www.altera.com.cn/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug-01073-1_0.pdf Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
