14 years agohow to use single byte offset in function IORW?
I found the offset is 4 bytes in IOWR, I want to know how to set the offset single byte? thanks.
14 years agoHi,
Anyone knows about the IOWR function declaration/definition? I need to know how the IDE drivers the data to pins of my component in SoPC. For example, if I have a LED_PIO with widht 8 bits, I just write IOWR (LED_PIO_BASE, 0, DATA) and I think the DATA will be sent to pins. But, if I have a component as DM9000A Ethernet controller, with 38 pins, where some are data and some are control, how I can set the correct pins to write a word? And how can I see the information about the order of component pins in IDE?
