14 years agohow to use single byte offset in function IORW?
I found the offset is 4 bytes in IOWR, I want to know how to set the offset single byte? thanks.
14 years agoThat's correct. This is the alignment you need to use for each:
IOxx_8DIRECT --> any alignment IOxx_16DIRECT --> 2 byte alignment IOxx_32DIRECT --> 4 byte alignment
