How to use On-Chip Memory in GHRD on Atlas-SoC board
Hello!
I want to transfer some data from FPGA to program that is running under Linux in HPS part. I am using DE0-Nano-SoC with 5CSEMA4U23C6 and GHRD. GHRD already contains On-Chip Memory in Qsys project and this memory is connected with HPS via h2f_axi_master. I was trying to store 32'hF0F0F0F0 words from within ghrd.v and then read it in Linux by opening /dev/mem but it filled with zeros since 0xC0000000 that must be the base address of the memory untill +0x8000 Below is the part of ghrd.v that I was addedadccounter addr_cnt(
.clk(FPGA_CLK1_50)
, .rst(~KEY)
, .out(add)
defparam addr_cnt.W = 14;
soc_system_onchip_memory2_0 m(
.address(add)
, .byteenable(4'b1111)
, .chipselect(1'b1)
, .clk(FPGA_CLK1_50)
, .clken(1'b1)
, .reset(hps_fpga_reset_n)
, .reset_req(1'b0)
, .write(1'b1)
, .writedata(32'hF0F0F0F0)
, .readdata(datain)
); Whats wrong with such design? Why I can't get the data in HPS? Could anybody tell how to use this memory properly or point me to some examples? Thanks a lot in advance!6 Replies
Hello, did you figure it out?
Hello!
Yes I did, but I can't remember the solution exactly. Generaly I was just reperformed each step very carefully. I also remember that it was important to regenerate C libraries after design is generated and not to forget to use these new generated libraries in your C program. I'll try to remember the details and maybe repeate this again and I'll put the steps here - Altera_Forum
Wow, I still stack on it. On your code example you are using Second Instance of soc_system_onchip_memory2_0, because first one is created by Qsys in GHRD project by default. So, investigated situation by the in-system memory editor I'v found, that C code with base 0xC0000000 has access to the first instance, and your code makes second instance with these bytes (hF0F0F0F0) and there is no intersections.
I will appreciate if you can provide any examples of your code. I want: 1. write data from HPS to RAM 2. read it from FPGA Many thanks! - Altera_Forum
OK, I'll do my best to find the code. Actually I was chaged the operation system on my work station since that time and this project is somewhere in the backup file. I can't just open it and copy the code here but give a little bit of time.
I also not very happy with the solution I found - Altera_Forum
I also remembered that I became more happy when switched to lightweight AXI
Many thanks for the answers. I'v got it! The idea is using Dual-port for soc_system_onchip_memory2_0, then it is available for hps and fpga. So my question is solved.
