14 years agoHow to use nios2-corss compile tool in command line
Hello, I want to use the nios2-corss compile tool in command line (my operating system is Ubuntu 11.10). I want use this tool to compile some source files into ".so" files. In com...
14 years agoYou said you wanted to generate a .so - they are shared (dynamically loaded) libraries, and only apply to operating systems.
If you want to run compiler the IDE runs - in order to use your own makefiles (etc) - then just search for the directory they are in. Something like:find / -name '*nios2-elf-*' 2>/dev/null is rather brutal, but should work. Possibly they aren't installed with that prefix, so try looking for '*objdump*' instead. Another alternative is to download the compiler and toolchain sources and build it youself. Details (and some compiler patches) are on the wiki.
