19 years ago
how to use "msgget" in nios2 uclinx?
hi:
I use function ret = msgget(KEY_MQ_CORE, IPC_CREAT|0660); make successed.
After exec, but the return value is -1
I want to use cmd "IPCS" to check the ipc ID. but shell return: not found.
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
How can I do? The same function "msgget" used in other uClinx os is OK.
Why failed in nios2 uClinux? Why the cmd "IPCS" not support nios2 linux?
Thanks a lot.
    --- Quote Start ---
    originally posted by hippo@May 11 2006, 09:11 PM
    please check ~/apps/mqueue .
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15310)
    --- quote end ---
    --- Quote End ---
    I make ~/apps/mqueue but failed. So I rework the Makefile of mqueue .
    But I meet a question. If I want to use mqueue ,frist I must make ~/apps/mqueue/src to make libmqueue.a
    So I added "ar = nios2-linux-uclibc-ar&#39; id makefile.
    but in make process, the cc use gcc not nios2-linux-uclibc-gcc,so the libmqueue.a
    is wrong.
    --- Quote Start ---
    originally posted by alex824+may 12 2006, 02:51 pm--><div class='quotetop'>quote (alex824 @ may 12 2006, 02:51 pm)</div>
    --- quote start ---
    <!--quotebegin-hippo@May 11 2006, 09:11 PM
    --- quote end ---
    --- Quote End ---
    is wrong.
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15316)</div>
    [/b]
    --- Quote End ---
    Please look at download/mx140apps.diff, and modify the Makefile.
    --- Quote End ---
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15319)</div>
    --- Quote End ---
    Thanks hippo.
    I have already rework ~/app/mqueue fo following mx140apps.diff.
    But the mx140apps.diff not dabble at the link *.A .
    Can you give us a template?
