19 years ago
How to use jffs2 in flash ?
hi hippo
I can cp -a some dirs to /mnt on uclinux with using initramfs.
In other word, i have build rootfs in my flash(mtdblock0)that can mount it to /mnt dir, and i can see some dirs in /mnt dir.
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
BusyBox v1.1.1-pre0 (2006.04.20-12:52+0000) Built-in shell (msh)
Enter &#39;help&#39; for a list of built-in commands.
# mount -t jffs2 /dev/mtdblock0 /mnt# cd /mnt# ls -l# mkdir proc sys var tmp mnt# cp -a /init /etc /dev /bin /sbin /usr /root /home /opt .# ls -l
drwxr-xr-x 2 root root 0 Nov 29 17:00 bin
drwxr-xr-x 6 root root 0 Nov 29 17:00 dev
drwxr-xr-x 4 root root 0 Nov 29 17:00 etc
drwxr-xr-x 3 root root 0 Nov 29 17:00 home
lrwxrwxrwx 1 root root 10 Nov 29 17:03 init -> /sbin/init
drwxr-xr-x 2 root root 0 Nov 29 17:01 mnt
drwxr-xr-x 2 root root 0 Nov 29 17:00 opt
drwxr-xr-x 2 root root 0 Nov 29 17:01 proc
drwxr-xr-x 2 root root 0 Nov 29 17:00 root
drwxr-xr-x 2 root root 0 Nov 29 17:00 sbin
drwxr-xr-x 2 root root 0 Nov 29 17:01 sys
drwxr-xr-x 2 root root 0 Nov 29 17:01 tmp
drwxr-xr-x 5 root root 0 Nov 29 17:00 usr
drwxr-xr-x 2 root root 0 Nov 29 17:01 var# cd /# umount /mnt# ls
bin etc init mnt proc sbin tmp var
dev home lib opt root sys usr# [/b]
--- Quote End ---
Check rootfs in mnt dir.
--- Quote Start ---
drwxr-xr-x 2 root root 0 Nov 29 17:01 var# cd /# umount /mnt# [/b]
--- Quote End ---
Q1: How to do that next step ?
Q2: If i want to store some files in flash with using jffs2.
How to do it ?
Can I use "nios2-flash-programmer" command to store files to flash in sdk shell ? or i need to change specific format for programming flash.
Thx !
    --- Quote Start ---
    originally posted by hippo@Jun 4 2006, 06:13 AM
    good. you don&#39;t need the dirs for rootfs in jffs2 now. you can use jffs2 mount all for user data.
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15866)
    --- quote end ---
    --- Quote End ---
    hi hippo
    Thank u !
    OK ...
    I will erase all dirs and save user data in jffs2 dirve.
    jay
