9 years agoHow to save Nios II console contents.
In the NIOS EDS environment I need to save the contents of the NIOS console which displays the output of the printf statements. I have tried to copy from the window and paste into another pro...
9 years agoI realize this is an old thread, but thought I would comment in case it is helpful for someone else.
If you want to copy from the Nios II Console and then past to a text editor , you can try this to see if it works... save printf output from nios ii console: • Currently using Eclipse from Quartus Prime 17.0. Not sure if this works in other versions. • I have not found this documented anywhere, just found it by trial and error. • Prior to clicking the run button, kill the Nios II Console window if it is open. It will re-open when it starts running. • During/after run has executed, select text in Nios II Console window. • Select Ctrl-Insert key combination. It should now be copied to the clipboard. • Paste with Ctrl-v. • This only seems to work once. Must kill window and re-run to do another copy/paste.
