19 years agoHow to return eCos configtool view to norma?
I have inherited a project with uses eCos on the NIOS2. I have a working .ecc. However, when I last started the config tool, a message flashed by on the status pane about the repository location (I ...
15 years agoI don't know how to thank you enough. I just lost 4 hours over this!
For documentation purposes, I see in my registry entries that the width of the configuration window has an abnormally large value that is very suspicious w/r to this bug. ecos configuration tool/window size/ConfigPaneWidth 0xffffff9a ...while all other widths of the gui are set around 0x00000570. I see it now has a similar value in the new registry entry.
