9 years agoHow to recover Arria 10 QSPI flash daughter card
Hi
I am able to boot the QSPI flash daughter card with the default image. Then i built the QSPI u-boot using the below configuration make socfpga_arria10_qspi_reva_defconfig then converted the u-boot-dtb.bin image using mkpimage tool to u-boot-mkpimage.bin mkpimage -hv 1 -o u-boot-mkpimage.bin u-boot-dtb.bin u-boot-dtb.bin u-boot-dtb.bin u-boot-dtb.bin then programmed the QSPI flash using below command tftp 0x8000 u-boot-mkpimage.bin sf probe sf erase 0x0 0x100000 sf write 0x8000 0x0 0x100000 I followed the Arria 10 QSPI flash memory map as shown below https://rocketboards.org/foswiki/view/documentation/a10gsrd161qspiboot Now the Evaluation board is not booting and how can recover back the flash daughter card ?3 Replies
Hi, perhaps the link below can help you:
https://rocketboards.org/foswiki/view/documentation/arria10nandflashprogramming - Altera_Forum
Thanks sunshine,
i am able to recover back my flash daughter card using USB Blaster and quartus_hps jtagconfig jtagconfig --getparam 1 JtagClock quartus_hps -c 1 -o PV /home/Desktop/devkit/qspi_image/u-boot-_w_dtb-mkpimage.bin u-boot-_w_dtb-mkpimage.bin is the default built in binary from rocketboards.org below is the link for QSPI mapping https://rocketboards.org/foswiki/view/documentation/a10gsrd161qspiboot - Altera_Forum
Glad to hear that! Thanks for sharing :)
