15 years agoHow to read from a onchip memory
Hello i want to read data from some adress at the onchip memory, i can do it with IORD and IOWR using altera HAL functions. However those functions are not available for me inside the linux
15 years agoYou won't be able to access memory directly from userspace in linux. You'll probably have to write a kernel driver or module. On the other hand, You can access heap memory if it is set in BSP config by using malloc().
