15 years agoHow to Pass an Extra Option to 'elf2hex' in a BSP's 'mem_init.mk'
Hi, This is a question for someone who is familiar with the NIOS II building system. When executing 'make mem_init_generate' I want the extra option '--record=4' passed to elf2hex. It seem...
14 years agoHi,
I have the same problem with quartus v9.1 sp2 (I'm forced to use this version to be compatible with an IP license). Did you find a solution to add the --record=4 parameter to elf2hex command without modifying manually the script ? Regards, Claude
