9 years agoHow to Initialize Char LCD using PIO (De0-Nano)
Hello to the whole forum, this is my very first thread so please be kind with me(=
I'm trying to drive a char LCD using my de0 nano but no results yet.. My lcd is a 5v unit but since I need just to write to it I guess it wont be a problem, except for a bit weak logic 1 but according to data sheet it should work. I tried the altera university core for 16 x 2 char LCD but since I must keep the reduced drivers enabled this seems not the right option to save memory, anyway this core was able to properly initialize the LCD so I must have made some coding/timing error. In my new implemntation I drive it with 2 separate PIO, one for RS, R/W, En + one for Data. The PIO_LCD_COMMAND drives the 3bit output bus (msb is RS, RW, lsb is En), then the PIO_LCD_DATA drives the lcd bidirectional data bus. Here's the LCD data sheet if it may help: http://www.farnell.com/datasheets/2051086.pdf?_ga=1.268795697.1932054068.1473273391 Here below I've attached my initialization code, I hope someone might help! Much thanks guys :D IOWR_ALTERA_AVALON_PIO_DIRECTION(PIO_LCD_DATA_BASE, ALTERA_AVALON_PIO_DIRECTION_OUTPUT); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_DATA_BASE, 0x00); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE,0b000); usleep(16000); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE,0b001); usleep(100); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_DATA_BASE, 0x30); usleep(100); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE,0b000); usleep(4500); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE,0b001); usleep(100); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_DATA_BASE, 0x30); usleep(100); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE,0b000); usleep(200); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE,0b001); usleep(100); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_DATA_BASE, 0x30); usleep(100); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE,0b000); usleep(200); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE,0b001); usleep(100); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_DATA_BASE, 0x38); usleep(100); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE,0b000); usleep(200); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE,0b001); usleep(100); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_DATA_BASE, 0x08); usleep(100); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE,0b000); usleep(200); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE,0b001); usleep(100); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_DATA_BASE, 0x01); usleep(100); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE,0b000); usleep(200); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE,0b001); usleep(100); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_DATA_BASE, 0x06); usleep(100); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE,0b000); usleep(200);2 Replies
Hi I've been able to initialize it correctly.
I didn't set the biport output direction for all data pins. No I fixed it: IOWR_ALTERA_AVALON_PIO_DIRECTION(PIO_LCD_DATA_BASE , 0b11111111); Anyway I try to print some char after the initialization but no result, here's the code I used to print a char: IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_DATA_BASE, 0x80); usleep(1); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE, 0b001); usleep(2); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE, 0b000); usleep(200); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_DATA_BASE, 0x41); usleep(1); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE, 0b101); usleep(2); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE, 0b100); usleep(200); I take some wide timing since I wanted to be sure the unit has time to do its internal operation. - Altera_Forum
Everything solved, now I can print char and do stuff.
The second issue was caused by wrong timing. The Clear Display command is quite slow and it take 1.52ms to be done, so I Changed usleep(2000). As I said I've taken super wide delays since I wanted to avoid timing issue. This is my working/corrected code, I hope it may help someone: IOWR_ALTERA_AVALON_PIO_DIRECTION(PIO_LCD_DATA_BASE, 0b11111111); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_DATA_BASE, 0x00); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE, 0b000); usleep(16000); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_DATA_BASE, 0x38); usleep(1); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE, 0b001); usleep(2); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE, 0b000); usleep(4500); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_DATA_BASE, 0x38); usleep(1); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE, 0b001); usleep(2); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE, 0b000); usleep(200); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_DATA_BASE, 0x38); usleep(1); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE, 0b001); usleep(2); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE, 0b000); usleep(200); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_DATA_BASE, 0x38); usleep(1); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE, 0b001); usleep(2); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE, 0b000); usleep(200); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_DATA_BASE, 0x0E); usleep(1); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE, 0b001); usleep(2); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE, 0b000); usleep(200); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_DATA_BASE, 0x01); usleep(1); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE, 0b001); usleep(2); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE, 0b000); usleep(2000); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_DATA_BASE, 0x06); usleep(1); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE, 0b001); usleep(2); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE, 0b000); usleep(200); //data to test lcd IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_DATA_BASE, 0x41); // A usleep(1); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE, 0b101); usleep(2); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LCD_COMMAND_BASE, 0b100); usleep(2);
