9 years agoHow to generate nois_code.c file for Altera Multiprocessor system
I am following your Altera Multiprocessor system design (https://rocketboards.org/foswiki/view/documentation/buildingmultiprocessorsystems2 (https://rocketboards.org/foswiki/view/documentation/buildingmultiprocessorsystems)).
After writing the sd_card_image provided by you on the sd card, I get lab1 folder which contains all programming files needed to perform lab1. I would like to know how to generate nois_code.c as this file contains only hex addresses? The nios_code.c file is located in directory /lab1/nios_code/nios_code.c Software file also bee attached Best Regards Aman BatraNo RepliesBe the first to reply
