16 years agohow to export macro to system.h?
eg, I want to put # define MOD_0_FREQ 50000000u to system.h as many altera sopc ip do. And I try to add some line in the MOD_hw.tcl: add_parameter FREQ_PARAM 0 set_parameter_property FRE...
14 years agoThanks for the posts, helped me get things working--with a caveat. I'm passing parameters for a custom instruction, and so I've added the following to my validation callback:
set_module_assignment embeddedsw.CMacro.SYNCHRONOUS [get_parameter_value SYNCHRONOUS] What ends up happening is that the parameter shows up twice in my system.h, once as # define "SOPC_MODULE_NAME"_SYNCHRNOUS 0 which is what I want and expect, and once just as # define SYNCHRONOUS 0 after the custom instruction macros, which I don't expect and is probably bad. Any idea what might be happening? It seems like a bug (I'm using the Web edition of 11.1sp1 in linux). Right now it's not a problem, but if I want to do something like have two custom instructions in the same system, bad things happen (#define SYNCHRONOUS happens twice, bsp generation fails).
