15 years agoHow to execute NIOS II Command Shell commands from a *.bat file
There is probably a simple solution to this, but I am having a hard time finding it in any of the documentation. I have four applications that I need to build for a single board. I can build t...
15 years agoI just tried the following and it just opens the command shell, but doesn't run the script
C:\>"C:\altera\91\nios2eds\Nios II Command Shell.bat " sh "C:\altera\91\nios2eds\test.sh" ------------------------------------------------ Welcome To Altera SOPC Builder Version 9.1, Built Wed Mar 24 22:13:17 PDT 2010 ------------------------------------------------ ------------------------------------------------ Welcome to the Nios II Embedded Design Suite Version 9.1, Built Thu Mar 25 01:25:52 PDT 2010 Example designs can be found in /cygdrive/c/altera/91/nios2eds/examples ------------------------------------------------ (You may add a startup script: c:/altera/91/nios2eds/user.bashrc) ~ [NiosII EDS]$
