15 years agoHow to Download ELF file with using command promat
Hi, I am using QII v11.0 with Eclips only(Not installing lagancy) on my machine. My question is have you guys every try to download ELF/FLASH file using .BAT files?(i.e using command like ...
14 years agoOn Windows 7 I use the following two commands in the command prompt:
<Quartus II Path>\bin\nios2-elf-objcopy <My Application Path>\<My Application name>.elf -O srec <My Application Path>\<My Application name>.srec
<Nios 2 EDS Path>\bin\nios2-gdb-server --cable="Usb-blaster " <My Application Path>\<My Application name>.srec --go
Thomas.
