15 years agoHow to Download ELF file with using command promat
Hi, I am using QII v11.0 with Eclips only(Not installing lagancy) on my machine. My question is have you guys every try to download ELF/FLASH file using .BAT files?(i.e using command like ...
14 years agoI recommend passing in the reset command as well. i.e. nios2-download -r -g <elf_file.elf>
If you want to open a terminal connection it is nios2-terminal. Both of these commands have cable options as well in case you have multiple programming cables. Use the --help to find out more about the syntax in those cases.
