14 years agoHow to disable RTOS?
Hi! Our Company is developing soft-processors using Nios I, but due to Nios I is not supported any more, as well as due to more advantageous JTAG use, we have to use Nios II. The problem we are ...
14 years agoAnd not a solution in this case, because even with only one task, the OS still uses the system timer and its interrupt to run the scheduler.
