14 years agoHow to disable RTOS?
Hi! Our Company is developing soft-processors using Nios I, but due to Nios I is not supported any more, as well as due to more advantageous JTAG use, we have to use Nios II. The problem we are ...
14 years agoDid You enable -Os optimization? Optimization is disabled by default.
Also You can run RTOS with only one task :) Well... rather more workaround than a logic solution.
