14 years agoHow to disable RTOS?
Hi! Our Company is developing soft-processors using Nios I, but due to Nios I is not supported any more, as well as due to more advantageous JTAG use, we have to use Nios II. The problem we are ...
14 years agoThis starts to be a bit out of my field, and I hope someone else will be able to answer, but I think there are a few things that are done by the HAL before going into main().
If I remember correctly you can avoid those steps and begin in a function called alt_main() instead, with fewer initialization, but you will have to search a bit to see how this is done.
