10 years ago
how to build poky yocto for cyclone v?
Hi all, I am new in the embedded Linux, I am trying to learn up how to build the boot up related files for poky in cyclone V, any guide or suggestion? appreciate for the helps. thx..
    --- Quote Start ---
    13.1 is a bit older generation of yocto build. why not just go for newer versions?
    --- Quote End ---
    I recommend just downloading a stable build of Yocto/Poky directly... I didn't realize it came with the EDS!
    jeinstei a.k.a Sensei.....
    Very appreciate for the basic guide and hint,,, as for now, i would just start to have all the reading according to your web link . This ia good start for me to learn up.
    --- Quote Start ---
    --- Quote End ---
    Pps.. I should say why not just go to get the 14.1 or 15.0 GHRD which is using another type of build, I saw is named as Angstrom.
    --- Quote Start ---
    --- Quote End ---
    Ah! Yes. You can use yocto or buildroot or really any good build tool as long as you have a good guide the first time!
    Please beware of version of the linux to build the yocto, especially that is not listed or tested by the guys who provide solution in the rocketboard.org. i came across for certain version pop for error. end up i just back rolled the operating system version in order to match the requirement.
    --- Quote Start ---
    --- Quote End ---
    Wile I in general agree, remember that linux I'd basically kernel or package based and it is possible to build your own packages from source, etc. In general, stick with known good versions, but if one knows the required dependencies, it is often possible to get things working. Especially if using Yocto to do a custom build, keep this in mind as the built linux version will also need to be vetted.
