14 years agoHow long should it take to write to flash?
I am just wondering how long it should take to write to flash, the following line of code takes about 8 seconds to update a 128k block of CFI flash memory. Is this normal? alt_write_flash ...
14 years agoWhat flash device are you using?
Usually CFI flash memories have a byte programming time of few us. But if I remember correctly alt_write_flash includes the erase sector cycles, even if memory is already blank. Each sector erase may require tens of ms, so you must consider it.
