AKhan8's avatar
AKhan8
8 years ago
How i can interface Arduino with DE10 lite FPGA board?
I want to read the output of a analog sensor. So is it possible that i can connect directly that sensor with my FPGA board or i have to use arduino. if i have to use arduino then how i can interface with it. thanks
  • You can't connect an analogue sensor output signal directly to an FPGA - you will need an ADC. Depending on the sensor you're hoping to use an Arduino board could be used.
    Cheers,
    Alex
  • AKhan8's avatar
    AKhan8
    I am using digital sensor TCS230. If you can provide me some sample code that how i can read or write on that sensor using my FPGA board I/O pins. Below is the link of my sensor and i am using DE10-lite FPGA board. Thanks @a_x_h_75
    http://www.w-r-e.de/robotik/data/opt/tcs230.pdf
  • Post any code you're having trouble with (I'm not writing it for you) and we'll help.
    Cheers,
    Alex
  • AKhan8's avatar
    AKhan8
    This is my code and still i got no success. Plz help me . Thanks
    module test1
    input fr,en,clk,  //input light value
    output reg M1, M2, M3,s2,s3,
    output s0,s1);
    //parameter frequency = 1'b0;
    //setting frequency-scaling to 20%
    //states
    assign s0 = 1'b1;
    assign s1 = 1'b0;
    reg [15:0]count,count_next;
    reg [15:0]counter,counter_next;
    wire [20:0]interval;
    reg [20:0] interval_next;
    wire [15:0] div;
    always@(*)
    if(interval=='d24000)
    begin
    s2<=1'b0;    //red
    s3<=1'b0;
    end
    else if(interval=='d48000)
    begin
    s2<=1'b0;
    s3<=1'b1;   //blue
    end
    else if(interval=='d96000)
    begin
    s2<=1'b1;   //clear
    s3<=1'b0;
    end
    else if(interval=='d120000)
    begin
    s2<=1'b1;
    s3<=1'b1;
    end
    always@(posedge clk)
    if(interval <='d120000)
    interval_next = interval+1;
    else
    interval_next = 0;
    assign interval = interval_next;
    if(div < 'd4545 && en == 1'b0)
    count_next = count + 1;
    else
    count_next = 0;
    always@(posedge fr)
    counter_next = counter + 1;
    else
    counter_next = 0;
    assign div= count/counter;
    always@(*)
    begin
    M1=0;
    M2=0;
    M3=0;
    if( (div >= 'd3125) && (div <= 'd2083) &&  (s2 == 0) && (s3 == 0) )
    M1 = 1'b1;
    else if( (div >= 'd4545) && (div <= 'd2380) &&  (s2 == 0) && (s3 == 1) )
    M2 = 1'b1;
    else if( (div >= 'd3571) && (div <= 'd2083) &&  (s2 == 1) && (s3 == 1) )
    M3 = 1'b1;
    end
    endmodule
  • Have you simulated this code?
    There's quite a few issues in there that, I'm very sure, you'd spot if you did some simulation.
    Cheers,
    Alex
