16 years agoHow do Nios-II handle IP address change during the TCP/IP connection?
Dear all, I have problem with changing IP address in the FPGA board. Here is my case, let say I have a FPGA board which is connected to PC. The PC sends a command to the FPGA that asks th...
15 years agoOk, thank you very much!
One last question: Where did you defined your change_ip() function? I tried it in Web_server.c but even when I enabled DHCP in Nichestacks Settings under System Library it couldn't find the dhc_state_init() function.
