16 years agoHow do Nios-II handle IP address change during the TCP/IP connection?
Dear all, I have problem with changing IP address in the FPGA board. Here is my case, let say I have a FPGA board which is connected to PC. The PC sends a command to the FPGA that asks th...
15 years agoI did it just static.
But if you want to trigger actions through the webpage, you will find ProgFlashStub() in http.c. Here declare all the actions and which functions are called.
