16 years agoHow do Nios-II handle IP address change during the TCP/IP connection?
Dear all, I have problem with changing IP address in the FPGA board. Here is my case, let say I have a FPGA board which is connected to PC. The PC sends a command to the FPGA that asks th...
15 years agoI am failed at step 7. Since the step 7 is failed of course step 8 is also failed (because PC couldn't find the available socket)
Wow really?? are you sure you don't need to re-do the TCP/IP establishment? How can the previous TCP/IP connection is not broken? I've tried also without re-initialization of TCP/IP connection, but it was error on step 8. But the strange thing is I can ping the Nios with its new IP address.
