14 years agoHow can i read ans write on flash memory on uClinux
hello all I want to save some setting for my application need, so i want to use the flash, so how can i write and read from flash using driver or directly from applcation
14 years agoIf you don't need to additionally read or write the flash with any non-Linux system, IMHO the way to go is using a standard Linux Flash file system. I some time ago was able to read / write files in the flash of a NEEK dev board by just using what the community distribution provided out of the box. I used JFFS2, but AFAIK, nowadays UBIFS is recommended over JFFS2.
see: http://www.alterawiki.com/wiki/mtd http://www.alterawiki.com/wiki/flashprogrammer http://www.alterawiki.com/wiki/ubifs http://www.alterawiki.com/wiki/initialization_script http://www.alterawiki.com/wiki/using_haserl_scripts_for_html_based_runtime_configuration_and_monitoring -Michael
