How can I direct run nios programmer on epcs?
if i have not ram and less onchip mem,
How can I direct run nios programmer on epcs or sd card ?6 Replies
You can't.
The EPCS ROM and sd card devices can only be read by device drivers (etc). You could arrange to map multiple functions to the same addresses and load the code blocks are required (overlay loader) - but I'm not sure that has really been done since paged memory systems became common in the late 1970s. Another option is to enable the mmu, take the page faults and use that to dynamically page in the required code - but that is a lot of coding, and I suspect you won't have enough real memory for a reasonable set of working pages. - Altera_Forum
thank you.
can I use the serial RAM for example 23k256,because the FPGA pins is used full,do not use the parallel RAM. `timescale 1ns/10ps module M23K256 (SI, SO, SCK, CS_N, HOLD_N, RESET); input SI; // serial data input input SCK; // serial data clock input CS_N; // chip select - active low input HOLD_N; // interface suspend - active low input RESET; // model reset/power-on reset output SO; // serial data output // ******************************************************************************************************* // ** DECLARATIONS ** // ******************************************************************************************************* reg [15:00] DataShifterI; // serial input data shifter reg [07:00] DataShifterO; // serial output data shifter reg [31:00] BitCounter; // serial input bit counter reg [07:00] InstRegister; // instruction register reg [15:00] AddrRegister; // address register wire InstructionREAD; // decoded instruction byte wire InstructionRDSR; // decoded instruction byte wire InstructionWRSR; // decoded instruction byte wire InstructionWRITE; // decoded instruction byte reg OpMode0; // operation mode reg OpMode1; // operation mode reg Hold_Enable_N; // hold enable - active low wire Hold; // hold function reg [07:00] MemoryBlock [0:32767]; // SRAM data memory array (32768x8) reg SO_DO; // serial output data - data wire SO_OE; // serial output data - output enable reg SO_Enable; // serial data output enable wire OutputEnable1; // timing accurate output enable wire OutputEnable2; // timing accurate output enable wire OutputEnable3; // timing accurate output enable integer tV; // timing parameter integer tHZ; // timing parameter integer tHV; // timing parameter integer tDIS; // timing parameter `define READ 8'b0000_0011 // Read instruction `define WRSR 8'b0000_0001 // Write Status Register instruction `define WRITE 8'b0000_0010 // Write instruction `define RDSR 8'b0000_0101 // Read Status Register instruction `define BYTEMODE 2'b00 // Byte operation mode `define PAGEMODE 2'b10 // Page operation mode `define SEQMODE 2'b01 // Sequential operation mode - Altera_Forum
Years ago back in the nios forum days someone posted an EPCS controller that would allow you to do this. Mind you it would be incredibly slow and you don't want to use it for rwdata, heap, or stack otherwise you'll kill the Flash cells pretty quickly.
If your board is still in development I would recommend slapping a x8 DDR SDRAM on it since even if you get a controller that will allow you to run code in place out of flash, or page in code it's going to be pretty slow. - Altera_Forum
Thanks BadOmen ,Now only to modify my designed,but I 'm very interesting for run programm on epcs, other rwdata, heap, stack on onchip_mem,Can you tell me that post link?
This was a long time ago (4+ years) so I'm not sure if that design is still around let alone if the post for it was salvaged when the nios forum went belly up (it was a forum user that created it and not Altera). That said what kind of performance are you looking for with such a solution? I ask because if you managed to run code out of an EPCS device the performance is going to be really bad and all this work isn't worth it if you have performance numbers to meet. If you need code performance then you'll need to page in code to on-chip RAM like DSL said, but this can be a lot of work as well.
If you haven't already looked at code optimizations for reducing your footprint I recommend doing so over executing code out of the EPCS memory directly since that would make a world of difference in terms of execution speed. Running code out of EPCS with the appropriate controller would be like running an 8-bit CPU at 1MHz...... - Altera_Forum
Thank you very much,Where to select "over executing code out of the EPCS memory" ,I want to try,speed is not problem.
