VFigu
7 years agoHow can I call another C program with the SD-Card ?
Hello, I have a Nios II runing with a vga controller and a SD-Card controller. The Nios II starts with a C program at the on-chip memory, can i call another C program located in the SD Card, if yes,...
JOHI
Contributor
7 years agoHello,
What you want to do is basically what operating systems do.
Therefore try to go the Linux road (boot linux from SD Card), then you can start as many programs as you want.
Doing someting similar with Nios is a much more complex and elaborate task.
Johi.
