14 years agoHot FPGA after design upload
Hello, I've developed a board with EP3C40F324 FPGA which includes National Ethernet PHY and two separate DDR memory chips connected to banks (3,4) and (7,8). These particular banks are powered 2.5...
14 years agoWell, doing that test, I've removed parallel termination resistors (56ohm) and disconnected the 1.25V supply.
According to DDR specs, parallel termination must be used only if wire length on the board is >2 inches (>5cm). The longest wire on my board doesn't reach 1 inch limit, so I am within specs with that test.
