14 years agoHelp:DE4 can't run simple socket server normally
I make a qsys hardware for DE4 board,and intend to run a simple socket server but always failed. attach my qsys file and information for run simple socket server. # ########run inf...
14 years agoWhat about the initial cpu frequency on the working sample? I guess it was lower than 150MHz you are now using.
With f>100MHz you must carefully constrain your design in order to meet timing, while for lower frequencies you can afford looser requirements.
