14 years agoHelp:DE4 can't run simple socket server normally
I make a qsys hardware for DE4 board,and intend to run a simple socket server but always failed. attach my qsys file and information for run simple socket server. # ########run inf...
14 years agothanks again!
I had a dhcp server, and I can run well with the DE4 sample(sopc builder). I just make a project with qsys reference to the DE4 sample and altera ethernet sample. I want run cpu with high Fmax, 150Mhz. but I can't work first! so, I think I connect the network correctly and the dhcp server is ok. maybe somewhere is wrong,I will only debug and modify it with my effort. --- Quote Start --- If you want to use DHCP you need a DHCP server on your network. Do you have it? During initial testing you'd better disable DHCP and use a fixed well known IP address. If you can't ping it, there are a number of possible reasons: - your pc is not configured with the same subnet as the DE4 board. Check network settings on your pc - your fpga design is not fully constrained and it possibly has timing problems - other flaws in fpga design (i.e. pin assignment): did you use a standard sample design or did you build it from scratch? - you missed something in Nios bsp or application settings --- Quote End ---
