14 years agoHelp:DE4 can't run simple socket server normally
I make a qsys hardware for DE4 board,and intend to run a simple socket server but always failed. attach my qsys file and information for run simple socket server. # ########run inf...
14 years agoFirst thanks for you attation to my question.
I use DHCP Client to get ip. //but I can't work. or if I set the ip address,the simple socket server run,but I can't ping the DE4 I am confused! --- Quote Start --- Did you define a valid default ip address? The line IP address of et1 : 0.0.0.0 seems indicate no ip address has been defined. --- Quote End ---
