10 years agohelp:bsp generate error when copy from one another pc
Dear,
I copied a bsp and application project from one another pc, and successfuly "import an existing project" to the Eclipse workspace. When I build the bsp project, Eclipse poped an error message: " Makefile not up to date. ../../nios_28h_spi.sopcinfo has been modified since the BSP was generated. Generate the BSP to update the Makefile,and then build again. To generate from Eclipse: 1. Right-click the BSP project. 2. In the Nios II Menu, click Generate BSP. " After I right-click the BSP project and in the Nios II menu,click Generate BSP, and Error message poped: " SEVERE:file not found:..\..\nios_28h_spi.sopcinfo SEVERE:file not found:..\..\nios_28h_spi.sopcinfo SEVERE:nios2-bsp-generate-files failed " But really the .sopcinfo file exist in the right folder. The bsp and application project had been successfully build in the PC which I want to copy from. What happened? And how to resolve this problem? How to copy an existing bsp project from a different PC? Thank you for the help.1 Reply
Please try to use nios ii software build tools project -> import nios ii software build tools project instead of general -> existing projects into workspace. Regards, CH
